So after rebuilt carb, fuel pump, idling adjusting and repeated testing on driveway, I went out to the lake with a boating friend last week. Engine started right up, things went smooth and we were on the lake for an hour and returned home. We didn't stop the engine during that whole hour.
With last week's good experience, I took the family out to the same lake today. Engine started right up and we were cruising on the lake for 15-20 mins before we decided to stop at the middle of the lake and fish. So, we did fishing for about an hour.
Then the engine won't start (it would crank). After fiddling for about 3 minutes, the wife pointed to the MinnKota. I had no choice but hooked it to the starting battery (last time went so well so I didn't bring the deep cycle). the 50lb trolling motor definitely pushed all 4 of us back to the ramp in about 20 minutes but the trip was like forever.
I tested the motor on driveway many times, shut off and restart without problems. It's just at the lake where the problems will come. Other than unable to restart, the engine runs strong and idle fine. I don't know what else I need to do. I have noticed the engine seems to run differently (weaker) when the engine cover is on. When I tested it on driveway, the cover was off. The other place that I have not messed around much was the idling mixture adjustment. I just use the settings that most of you recommend (1 and 1/4 turns CCW).
I have lawn tracter, lawn mower, gas trimmer and pressure washer all using 2 cycles engines and never ever run into this problems. I just don't understand why it is so difficult to get an outboard reliably running.
Any suggestions? - AC
