Sliver
- Jul 19, 2006
- 47
Hello friends,
I have a 1981 70hp Johnson that runs great but I am not getting anything as far as charging voltage goes. 12.65 at battery both engine off and at idle up to 1500 or so. I'm not exactly sure of the stator/rectifier relationship so a brief summary would be good to hear. I performed the rectifier test outlined in another post and it failed. No continuity in either direction on 2 of 3 wires and continuity on 1 wire in both directions. Being as the rectifier is a fairly cheap item I plan to replace it. Should I be looking further up the system also? I gather that basically the rectifier converts the AC from the stator to DC to the system, am I correct and any other thoughts to get my voltage up? Your kind help is greatly appreciated.
