d_glover25
- Mar 7, 2007
- 47
I just replaced all the carb gaskets and hooked a new external tank and new fuel line to my 90hp outboard that was sunk. Cleaned out the cylinders and replaced all gaskets. Now it wont hold pressure in the bulb when running and will not idle. I can start it and take it to about 2500 rpm and it will stay running but when I adjust the idle screw it runs at a correct idle for a few seconds and then putts out. I would guess that its sucking air from somewhere but I cant find it and none of the lines or carbs are leaking gas. Any suggestions on where I should look or what to check. The bulb stays hard when the engine is not running.
