Re: 1956 Evinrude 3hp (3018) propeller not turning
There aren't any bearings to replace or seals to deal with - it's non-replaceable bronze babbit bearings throughout, which is why it needs the 24:1 oil mix. If the bronze bearings are worn beyond usability, the motor is likely junk, but when they wear out they usually go in grenade-like fashion. Being that your motor was running fine for those 200 yards, it should be a straight-forward take it apart, replace the crank and reassemble type deal. Wouldn't hurt to clean the ring grooves of carbon and scrape the rest of the exhaust cavity clean of carbon while you're in there, but there really isn't much else I would do. A light honing of the cylinder walls with a brake hone might help, too, but probably isn't necessary unless compression was really low or if there is some mild scoring.
I've done a few 3s over the years and could have a crankshaft replaced in an evening. Outboards don't get much simpler than these little guys...
As for cost, if the waterpump was recently new, and the coils have been replaced within the last 25 years, there probably isn't much else to replace as a matter of course. If the points are pitted, they can be replaced with change from a 10-spot. Even the impeller can be had for less than $15.00. Drop me a line and we can talk about the crank if you decide to go ahead with it... (csr112-n@prodigy.net)
- Scott
