mcleaves
- Sep 15, 2003
- 521
Hi Guys,
Been a while since i had a good problem to post here
I noticed this happening once on my last trip out and then today it happened a LOT, all at low RPM's
Simply put my steering locks up.. I will be turning the wheel as easy as pie with one finger and then BAM!, it's stopped dead as if it is already hard over. I have to turn in the opposite direction and give a good push to get it through. This never happens at high RPMS (at least I haven;t noticed it), only at head way speed and slightly above, which, of course, is when you usually do the most steering.
I thought it might be low fluid or a slipping PS belt but nope, all check out when I got back on the trailer. Any ideas on what could be causing this? It's not the cable (at least I don;t think it is) since it's happening in all different places in the steering range. It's more like after X degrees of turn it sticks, and you can start your turn from any place and it'll happen. It happens going left left or right.
I thought about air in the lines, but aren't these systems self-bleeding?
M
__________________
1995 Four Winns 238 Vista
5.0 OMC/SX Duoprop
Edit/Delete Message
M
__________________
5.0 OMC/SX Duoprop
Edit/Delete Message
