Re: ignition switches - four position to a three position?
so I wired the new ignition and got the boat started, however the gauges don't work - which I am assuming is the accessory hookup problem I had. The other is that the engine won't stop when I go to the off position. I have to use the choke to kill the engine.
The old iginition had the following terminals: A (Accessory), I (Ignition), M (magneto), S (solenoid), C (choke), B (battery)
The new ignition is has these terminals: I (Ignition), M (magneto), S (solenoid), C (choke), B (battery), and then another M terminal that was shaped differently.
So my question now is, what is the second M terminal for, and again, where do I hook up the accessory lead?
Thanks!
