supper sea hors johnson -35 1959
vVladimir
Hi to all! .Need any information(manual)gas-oil proportion and so for supper sea-hors Johnson-35 1959 ..thanks.
Joe Reeves
Re: supper sea hors johnson -35 1959
Spark plugs = Champion J4C or J6C, gap set to .030 . The J6C might give you better performance due to the engine's age.
Points = Have flywheel key aligned with fiber rubbing portion of the points. Set points so that a .020 feeler gauge passes thru but a .022 will not.
Gearlube = HiVis 80/90w, available at Wal*Mart, K-Mart, your local dealership.
Mixture = 50/1 = 1pt of 50/1 TCW-III oil to 6 gal gas. A octane rating of 87 will be fine.
samo_ott
Joe, is the '59 really a 50:1 mixture? As I have a '60 40hp which I thought was 24:1?
F_R
Here we go again. It was 24:1. A lot of people run less oil though. The arguement will never end, who is right. I say decide for yourself.
Joe Reeves
Sam..... Any engine that incorporates "all" needle, roller or/and ball bearings within its powerhead can safely use the 50/1 fuel/oil mixture. That includes your 1959 35hp and the 1960 40hp models.
