I was given a 4 hp Evin, Ser 4902B-E02509, 1969 suitcase motor. Its in great shape and easy to work on with the folding leg. I replaced the impeller immediately, new plugs, and started it using a 40:1 mix as recommended on this board. It started up and ran good but I could see no water coming out or mist so I shut it down quickly. The head was very hot to the touch. I checked impeller again to make sure the key was in place, it was o.k. I blew air into the water tube in the leg but I can not determine where it comes out other than back down the leg. Where should I be seeing the water exit from this engine? And, is there any way to check and make sure it is circulating? Thanks, Jim
