I have a 84 150 black max on a 18' procraft, it bogs and dies on take off, It bogs and dies when putting boat on trailer. Coughs, spits and sputters while idling. I have took carbs off and cleaned,checked the fuel line, put sea foam in the fuel, changed plugs.Did a compression test ( 110 psi on all cylinders ). you have to keep playing with it to get on plane. A month ago I put new prop on it,25p racker to 25p renagade.
It only turns to 4900 rpms at top speed of 55 mph. I have always had trouble with it bogging. I carry it back when I bought it (12yrs ago) they put used reed valve and block on it. Helped a little still had problems. I have ran it this way for 12 yrs ( thought it was prop).
