hello all,
I am new here and have been reading for the last couple of days trying to find a definte answer but have had no luck. here is my problem
I have a 89 mariner 135 hp V6 with the number C125663. When you give the motor gas it stumbles and bogs with no power up to about 2000-2500 rpms. Once you past this point and get in the 3000 range the motor runs great with no problems at all. oh yeah the motor also runs a little rough at idle. I have checkd that all cyclinders are firing at idle and they are.
Now ihave already checked the compresion on all six cylinder and they are all between 110-115. So it has to be in the fuel system or ignition. I am going to rebuild the carbs & pump this weekend just for piece of mind.
Now on the ignition/stator, I have read in here that this is the source of many problems these motors have. I have tested all the red and blue wires on the stator to ground. these were the results that i got.
Red - 153 ohms
Red/White - 151 ohms
Blue - 6340 ohms
Blue/White - 6310 ohms
Now according to book only the blue blue/blue-white are out of spec as it states they should only be 6200 ohms. The book does not give specs for the 40 amp system vs. the 9-16 amp system. I have forund three different web sites with different comber for both system. According to serail number of the motor it should be a 40 amp system.
I am confused as to where to go with this, what the actaul specs are for the stator are, and if my system is infact a 40amp system.
Maybe i am analyzing this to much. Any help would be greatly appreciated
Red - 153 ohms
Blue - 6340 ohms
