Re: any rendezvous owners (early 1990's)
Glennrow - I've a 2609 GA, year is '94 (I think), with a 175 HP Merc on it. I've had it for 2.5 yrs now, with few issues. Yes, I replaced the plywood/formica hatch for the head this summer. Seats need to be re-done also. It sounds like you've run into these as well. Other issue is a leaking hydraulic steering cylinder, but that's a Teleflex product, I believe. I'll be installing the seal replacement kit this winter.
Other things are what I would call normal aging, wear & tear: Needs a new bimini, and paint/epoxy coating on handrails is starting to peel.
In general, I can't really complain, and it is a really fun boat. Lots of room for out two young kids. Fast enough for us (about 38 mph on the speedo).
It sounds like you and rlamoreaux have both replaced seat cushions. I'm going to need to replace the "Wraparound seating" behind the driver, and the bench seat on the fwd port side. Driver seat is fine, as is a "fold out" cushion on the fwd starboard side. I'm afraid to price this work out, but I can't avoid it for much longer. What should I expect?
I will need a new cover soon as well. The existing cover has snaps on it, and I'm guess it's either factory or after-market custom. Have either of you replaced covers, and if so, any recommendations?
Also, what do you two have for trailers? My ShorLander is showing the effects of occasional saltwater use.
THANKS
P51D
