Kiwi Phil
- Jun 23, 2003
- 2,182
This is what I have done to date.
Pumped up 28,000 litres from the dam, (thru a screen filter on the dam inlet.....in front of the foot valve).
Screen filter definitely gets out all the bug/solids etc.
Water is very red from dissolved clay. Nothing else in it.
Bought a DE filter.
It dosn't work too well as it blocks and blows a fitting off after filtering about 2,000litres.
So: I put the water thru the sand filter first. Circultate it thru about twice.
It left a red floating-bubble-type scum on top.
Tried to scoop it off with a sieve but it is too fine.
Then thru the DE filter, but it blocks after about 5,000litres.
Water was no longer red (from clay) but a grey colour.
So I decided to try again.
This time when I filled the tank, I added Allum (flock).
I also added chlorine bringing it up to 10ppm free chlorine.
Next day it fell to 5ppm.
Next day zero.
So I ran it through the sand filter and in to another tank.
It went from red to grey.
No red scum on top.
Brought it up to 10ppm free chlorine (may have been higher, as my test sticks only go to 10. (It goes real #@%*% purple tho).
next day it fell to 3ppm
next day it fell to 1ppm
The ph fell with the addition of Allum, (to 7.2) but still well within my growing range.
So..........this is what I am hoping i have achieved and why I THINK is is OK.
If I got the free chlorine to 10ppm, and it took 3 days to drop to 1ppm, and 1ppm is suffiecient to kill the bugs I am concerned with, then irrespective of the colour of the water (from red to grey) I should have sterile water.......shouldn't I????
Keep in mind, the plants don't mind what colour the water is.
What comments do you have.....anybody.....as this is a learning curve for me.
I used the water for a week in my system and all the plants look healthy.
Do you have a site for a simple DIY test kit for e-coli?
I think it would be good if I could test often/easily/cheaply.
As a side issue:
you would laugh your butt off as to how I have set everything up.
Bought 3x15m lenghts of creepy-crawly 40mm flexible pool hose, and a box of 40mm irrigation fittings and appropriate hose clamps (barb one end...thead the other).
Have cut the hose up in to all sorts of lengths.
This way I can experiment to my hearts delight by switching from one tank to another as with pumps and filters.
Cost a bit, but cheaper than fixed pipe.
Every connection drips/leaks.
When I get it all worked out I will go with the fixed pipe.
Must have spent 40hrs on it so far, even out there in the dark some nights and early mornings.
Place looks a shambles with all the hoses.
Thanks in advance
Cheers
Phillip
Bought a DE filter.
Next day zero.
No red scum on top.
As a side issue:
Thanks in advance
Cheers
Phillip
