hi- its a 1980 85hp, has a starting problem. Sometimes it would start with the key , you could run around and if you turned off the motor, 10 seconds later won't start, would have to pull start. Got a new starter put on, thought the problem was cured but its not. starts after you touch some of the wires going into the starter. They have been tightened down, problem still exists. help
