1997 3.0ltr 4 cyl merc
Packers4ever
Hi Guys,
Can someone tell me if I should have a gasket between my thermostat and the housing other than the standard "paper" gasket my engine seems to run a little cool...my buddy has an OMC and he has a rubber gasket between the thermostat and the slot where it sits.
Thanks!!
Packers4ever
Re: 1997 3.0ltr 4 cyl merc
Can anyone help me?
I mean the hollowed out circular area where the thermostat recesses itself in the housing, is there a rubber washer or something that should go between the steel housing and the thermostat to create a seal?
Thanks
Packers4ever
Thanks Haut!!
I checked all 3 diagrams and none look like mine, but your right in all 3 it shows a rubber gasket either on top or underneath the thermostat, I geuss I will ask the mercury dealer in town.
Thanks!!
Don S
The link Haut gave you is for a V8 engine, so it's not the same at all.
Here is a link for your 3.0L Click here
It doesn't show any rubber gasket, only the paper.
Packers4ever
Thanks Don,
I geuss it just sits metal on metal.
Don S
How deep is the groove in the thermostat hsg. There could be a rubber ring with the thermostat that doesn't show on the parts breakdown, but I doubt it.
Packers4ever
The groove is just enough to recess the thermostat...maybe and 1/8th of an inch???
Maybe I should buy a new thermostat and see if it comes with it???
tommays
I have changed my 1995 3.0 many times
Just a stat and gasket No rubber ring ,it works fine
Tommays
