dirtyoldman
- Apr 30, 2007
- 359
I have a 69 Mark Twain boat with the 160 HP mercruiser straight six in it. I just bought it and haven't taken it out yet. I got a new battery and new bilge pump for it and have been cleaning it up. It runs great and I have a full tune up kit for it.
Just before I took it to the lake yesterday, I started it and it wouldn't rev. It ran out of fuel. THe fuel filter attached to the pump was full, but none at the carb. I pulled the pump and it was completely dry - not even wet. Nothing inside looked bad to me, so I put it back together. Still no start. Fuel drips from the tank line, but not as fast as I would think it should.
Now the really confusing stuff. The fuel pump has a weep hole - I thought marine ones don't. There was a line going from the outlet of the pump to the inlet of the fuel filter with what looked like a check valve in it, which was full of junk. I removed this to see if it would pump without this, because it didn't look like it should be there to me. It still won't pump. I have no return line from the carb and my distributor has a vacuum advance on it.
So here are my questions
1) Do I have the right fuel pump?
2) Where can I get either the kit or the right pump?
3) is there a sock on the pickup in the tank that might be plugged?
4) can I mount a big filter like my diesel has on the transom?
5) what was the bypass line on the pump?
6) How do I tell whether I have the right carb or not?
7) Do I have the right distributor? Does it matter?
8) Is there anything else I might be missing here?
Thanks,
Mike
Thanks,
Mike
