i have a 84 bayliner with a gm 350, 270 outdrive, aftermarket intake, point conversion to electronic, just put the motor back together got it started but i think it is 180 off, will an engine run 180 degrees off and if so what is the best way fix it. pull the dist and bump the motor around a turn or what thanks for the info pb
