fseventy
- May 20, 2005
- 47
1975 johnson 135. Trying to get the lower unit off to replace the impeller. I have a manual and I'm following it. I completely disconnected the shift linkage so that should not be a problem. Removed the 4 bolts holding the lower unit on as well as the trim bolt and the other bolt in the underside. The only thing I did not do is remove the prop. Is that why? I've hammered on the unit with a rubber mallet to loosen it up, but nothing.
If I have to take the prop off, any special instrictions? I can't get the cotter pin out is why I skipped that step.
