I've gotten my hands on an old Starcraft 14' shallow V with bent oak gunwales instead of aluminum. There are rotten spots in the gunwales from old screw holes, water pooling between the sandwiched boards, etc. The rotten spots are "cavities" from the top, with good wood on either side and the bottom. To get a couple more years out of the old gal I dremmeled out the rotten spots like a dentist and packed them with 2 part Marine Epoxy adhesive - it mixes to about the consistencey of toothpaste. To my astonishment the repairs are GREAT! That white stuff filled the voids, got hard as Heck, and it now looks like it's worth doing a real repair job using the old wood vs replacing it. The sides are MUCH more ridgid. Bonus city! I've srtipped off all the hardware (oar locks, tie down guides, weird brackets, anchor brackets . .). I've wire-wheeled off the old paint that would come off, and the rotten surface wood, and dremmeled out the remaining small rot cavities. I'm about to mix more Marine Epoxy Adhesive to fill the rest of the screw holes and minor rot cavities. Then I plan to seal the wood with "bondo" brand polyester fiberglass resin minus the hardener. I've got 2 gallons of the stuff from a friend. Then I'll apply more "bondo" polyester fiberglass resin , with hardener this time, and lay overlapping strips of fiberglass cloth over the entire gunwhale, bow to stern. That should make it very strong and water tight. So . . .
1) How soon after I fill the voids & screw holes with 2 part Marine Epoxy Adhesive can I seal the wood with the raw poly resin? Does the epoxy have to cure entirely or can I just start slapping on the poly as soon as the epoxy adhesive is set?
2) How soon after sealing the wood with the raw poly can I start laying my overlapping fiberglass cloth pieces saturated with poly & hardener? Does the raw seal coat have to cure first or can I just get going with my glass layers right away?
Any tips are much appreciated!
