Been having a ongoing problem with lack of power and rpm. Finally able to get all 3 cylinders firing. Still I have the same problem as always, lacking power and low wot rpm. It was suggested that I do a leak down test. I had trouble with the equipment and failed to obtain readings during the leak down test but, something interesting happened. When I pressurized no.1 the air pressure was leaking into no.2. The more pressure applied the more pronounced the pressure leak. Is it possible that I have a head gasket leak? If so, could this cause the lack of power and the low rpms that I have been trying to correct all along? Any suggestions would be a great help.
Thanks!
Thanks!
