Re: fuel shut off valve
Well I just installed a new fuel valve,took the needle valve out also and scraped off some green goop that was stuck in the little ridges,puit her in a tank and away she went,I did notice a little exaust and a small amount of water coming from where the shifter is located,if I put a little pressure on the shifter it stops.I doesnt seen like too much of a problem,but i wanted to run it by you guy's.Also I noticed a bit of gas dripping from the lower leg somewhere when I took the motor out of the tank,I assume this is left over from yesterday when the needle valve stuck and drained 1/2 a tank on my floor and all through my motor.
I flushed the motor in a tank for about 15min's hoping to clean it out.
Take Care
Aaron
