Re: Did manufacturers use treated plywood 25 years ago?
if you could perfectly seal any wood it would last forever. treated is to prevent wood destorying organisms, termite, fungus, not water rot. thats why the say mound dirt around your fence post so the water will run off, not puddle. where does a treated fence post rot. at the surface, not in the ground or in the air. water will destroy any wood, even marine ply, it just takes longer. i say use good exterior solid core plywood, seal it the best you can, and go on with your like. 40 years in the home construction and remodel industry.
