Re: Johnson 90 HP Ignition Problem
I'd say the timerbase (trigger as reeldutch calls it) is the next thing to check out. This is the thing that rotates under the flywheel (next to the stator) as the throttle is opened and closed. It has a series of coils that send a low voltage signal (0.5V) to the powerpack (or powerpacks in your case) at an appropriate time to fire each cylinder. The timerbase position determines the ignition advance as the throttle is opened.
You should measure about 40 ohms between the white wire and each of the four trigger wires (should be blue, green, purple & pink). Can you see any goo seeping out of this part. This is normally a sign of a failed unit.
Have you got a shop manual?
I also read this:
Engine runs rough on one bank (4, 6 and 8 cylinder engines with CD ignitions):
DVA check stator voltage to both sides. The readings should be fairly equal. If it exceeds 400 volts, replace the pack on the bank. If unequal, swap banks with the stator leads and see if the problem moves with the stator leads. If it does, replace the stator. Disconnect one of the black/yellow kill wires, AT THE PACK. If the problem goes away, replace the pack that was running smooth as is probably has a bad blocking diode.
