I have an OMC stringer mount and I'm trying to pull out the engine for overhaul. I suspect the ball gear shaft is rusted at the flywheel. All the bell housing bolts are removed but I can't separate the engine from the intermedaite drive. I can't pull the ball gear shaft out the back either. In the book I have, under the section for pulling the shaft, it says (after trying a slide hammer) you may have to pull the engine first and drive the shaft out from that side. That doesn't make sense to me. If I cant pull the shaft, I can't pull the engine either. I must be missing something. Is there anything at the flywheel other than rust that could be holding this?
