imported_DANA1
- Dec 9, 2006
- 51
i have seen diff. opinions concerning the use of muffs on alpha one drives. i have a1997 mercruisr 5.7 carbed, with a 1990 alpha one closed cooling 1/2 system "block only" i think raw water comes from impeller on outdrive? then flows thrue heat exchanger then out exhaust? if i increase my rpm the temp guage reads lower then at idle, both on muffs and in water so isnt a higher rpm cooling better?
