boatingfromthepoorhouse
- Mar 17, 2007
- 29
Hi all,
Just bought this boat & motor. Got it cheap cause I knew motor had trouble. Kid I bought from had carbs cleaned 2 years ago. let it sit a year, got left on lake dead...then I bought it - cheap! I checked the water pump, output appears to be ok on hose. Fuel has been stabilized and dewatered. Plugs are firing. I can start it ok now after reading some of your posts! It pays to just read!
But I still run rough, barely get it in gear and it dies. I do not see gas coming out of the carbs. But my plugs are wet every time I check/clean them. i think a carb rebuild and water pump are definitely called for...but i read something about reed valves? What name brand reed valve do you recommend? I may as well get them done while I have the carbs off. I do all of my own work, I have to - poorhouse and all... Please give any advise to a new to rude's semi-experienced shadetree mechanic.
thanks. God Blesses all good deeds
o
o
