Re: 5.7 carb manifold need to buy new help
If you have a 350 mag, the cast-iron manifolds are still for sale, and not much more than the alum edelbrocks. If you are far away, than the shipping cost might climb.
http://www.gmpartsdirect.com/results.cfm?perfPackages=1&curpage=3&startrow=11&pkgid=51
GM PART # 14096011
CATEGORY: Engine Fuel Intake Manifold
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $241.00
OUR PRICE: $175.45
DESCRIPTION: MANIFOLD
This manifold is a cast iron version of the aluminum Z-28 intake manifold. It offers the breathing benefits of a high-rise intake manifold in a less expensive package. It is recommended for Chevy enthusiasts on a budget, and for racers competing in classes which require a cast iron intake manifold. It is also suited to marine applications because cast iron is less susceptible to corrosion damage than aluminum. Technical Notes: The carburetor mounting pad accepts both standard flange and spread-bore four-barrel carburetors. This manifold is identified by orange paint on the Bow Tie.
GM PART # 14097494
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $241.00
OUR PRICE: $175.45
This high-rise cast iron manifold fits all 1987 and later 305 and 350 Chevrolet engines with cast iron cylinder heads. This is the same height as the Z-28 aluminum manifold P/N 14096011. The difference is the center two bolt holes are at 72º angles by spot facing the flange instead of the normal 90º angle. No EGR design. This manifold replaces P/N 14096241.
