Re: chrysler 55 hp engine
rtransue said:
I hate to ask this, but this is the first boat I have owned, and I am 63 yrs old and disabled.
I would appreciate any help I can get.
Thank you
Richard
Welcome to iboats, Richard.
Why do you hate to ask a question? We all have questions every day, yours just happens to be about a boat today.
And, you won't be 63 years old for long.
Once you get the boat in the water, it will take a few years off that age and make you feel about 55 again. d
I hope I'm still trying new things when I reach 63.
Not sure what being disabled has to do with it, you are a fellow boater now.
If you are a tinkerer and want to service your motor yourself, the first thing to do is to pick up a repair manual that covers Chrysler outboards. A manual by Clymer or Seloc will do.
After learning about how your motor works, come here for any clarifications and help.
Mercury dealers or Mercruiserparts (dot) com are your sources for factory parts. For aftermarket parts, there are many online dealers, including the iboats mall and maxrules (dot) com
If you don't plan to work on the motor yourself, you need to find someone that can and will. Many dealers and big shops won't work on Chrysler motors. Your best bet is to ask around where ever you can. Boat shops, bait shops, fellow boaters at the boat ramp, etc. Often times a small independent one man shop, is the place to get these motors serviced.
If you tell us where you are located, perhaps another member can recommend a shop for you.
Have your motor checked out and serviced, so that your boating adventures are happy ones.
Speaking of the boat ramp; learn as much about trailering, launching, loading, and boat ramp etiquette as you can. Best to spend a few hours on a Saturday morning, watching others launch and load. This will give you good opportunities to make friends and ask "how-to" questions.
Also, if you need to, go practice backing the trailer. Any large empty parking lot will do.
Your first couple times on the water will be an experience. Best if you can find a friend or fellow boater that will show you the ropes.
If you cannot find the hull id number on the back of the transom, you can make up your own number and engrave it on there, then use this number for your registration paperwork. The same goes for the trailer. Check with the authorities first, you may not need these numbers to register an older/smaller boat.
Welcome aboard, and Happy Boating.
