Ok folks, I apologize if this gets long winded,but I try and explain everything as much as possible.
We (a group of 4 guys) are proud owners of a winnabego(sp?) from the early 70's I think 73,but not 100% sure.....This motorhome is used up to 2x a year and thats only for the nascar races up in Michigan.....The previous owner welded 2" tube steel to the front and rear bumpers and built a platform that sits above the roof....I believe its framed with either 2x4's or 2x6's...Pretty shoddy workmanship to say the least...But it works for what we need it to do.....
The roof is leaking and now we have this big old heavy platform above our roof that needs replaced.....
With the wheels in my head turning....
Im thinking along the lines of tearing off the big heavy platform completely....Tearing off the roof completely...Im picturing using 2x6 metal studs for the new roof,with 1/2" plywood or the likes on the top...And cover that with a nice new slab of rubber roof I got off the last construction job I was on.....
I have the knowledge and knowhow to frame this together,and I think the 2x6s metal studs all tied together with some cross supports tossed in,plus the plywood would be plenty sturdy to handle the weight of 8 or so people on top watching the race....Not to mention should lighten up the load for traveling purposes.....
My main concern is how would I tie this 2x6 platform to the existing walls,and make it safe to travel down the road at 60+mph?
I know the walls on motor homes are not that thick,so Im worried on how to connect it all together...
Currently there is a metal adjustable support pole (like what you find in basements under the main joist) which helps support the weight on the roof,so Im not to worried about sagging or anything like that....
Any ideas would be appreciated...
June isnt to far away and something has to be done with the roof situation we have now...
Thanks
Thanks
