I have 50 hp store for about a year after replacing the fuel and rebuiding the carbs it only runs on the bottom 2 cyclinders. If I remove plug wires they still create spark
so far I have replaced the stator and trigger.
Still did not fix problem
I have completed the following
Check coil ohms ok to specifcations
Swapped coil primary leads problem still exist
when I reoved the plugs the 2 not working have fuel
i have adusted carp to spects but note if i take the top carb and close the needle valve it still does not change the RPMs.
I disconected the rectifier and still no change.
The only thing I have not completed is the voltage check and I'm not sure how to do this can you help
Also I suppect at this time the power pack how can i checkl this.
The only thing else is the reed valves??? how can I check for this
any answer would be helpful. thanks frank
