I purchased a new starter drive (# 18-5679) for my 115 73 v4 Johnson. The bottom plate fits nicely, but the pinion gear, spacer, spring, and stop will not fit on the shaft -- the diameter of the starter shaft is too large.
I've compared the pinion gear to the old one and it appears to be identical in the # of teeth and spacing between the teeth. The problem is the shaft size. Any suggestions?
