shelikesit
- Nov 23, 2005
- 171
4.3 carbed mercruiser, 1993 electric feul pump.
the search function for this forum would make throw this computer out the back window.
im looking for the electrical check points for the feul pump. everything was fine until i got to the dock. it turned over once and wouldn't turn over again. before i start throuwing parts at it, im wondering if it's the ignition switch.
the pump is not coming on when the key turns to the run position. all connections all over are clean and corrosion free. by this, i mean they look like they've never been used. it's how i keep them. now im wondering if too clean is over doing it. could i be screwing something up bathing my motor in corrosion block.
if the pump doesnt come on with the key turn, i believe the ignition switch is the first place to start, am i correct on this? if i pour a tad of gas in the carb, it fires. and no, i dont spray starting fluid in gas engines.
