Re: Nervous Gauge
How do you know its accurate if you split the difference? The only way to know that is by measuring oil pressure with a known good gauge. Use a mechanical gauge to check oil pressure. If its steady, its very likely a sender problem. If its still varies, its an internal engine problem. Now back to your original statement -- "varies by 1/4-inch". Under what conditiions? If it varies with engine RPM that's normal. Pressure at idle is less than it is at higher rpm -- after all, its a pump. If it varies at any rpm (idle, midrange, or wide open) that's a different story. Which is it and it would be handy to know what engine we are talking about.
