Re: Mercury 200 92' oil injection problem
I would suggest running premix in a seperate can and then disconnect the oil line to check the oil flow. Somewhere in the Mercury OE Manual it tells what the flow should be. at idle it mixes 100-1, at full RPM/Throttle it will mix 50-1.
Also, the check valves could keep pressure in the tank, forcing oil in the system, but that should not affect continous smoking while running, just heavy smoke on start-up. Try burning a synthetic blend oil, that will reduce some smoke but not completly. If you come in from a hard run and have heavy smoke at idle while docking, then I would say you are getting too much oil.
