Re: Choke on 1988 90 hp Johnson
Based on what you guys have told me it has to be the switch. I use the same starting procedure you just outlined with the red handle parralllel to the primer body. Turn the key and won't crank. Shouldn't you hear the primer solonoid clicking when it is working?
Yes, you should hear a "click".
As you are running the engine-NOW, you need to turn that handle back to parallel for running. Otherwise, you will dump serious amounts of fuel into that engine-not good.
Before you condemn and buy a switch, do the basics. This whole thing may be as simple as a ground issue. Crossflow engines are notorious for corroding the negative battery connection, at the
engine block. Remove the ground cable from the engine block (battery disconnected) and clean all the surfaces thoroughly. Retest, after that.
Also, grounds in the control box are critical. Make sure those are good. Don't just tighten, remove and clean.
I avoid replacing ignition switches at all costs. Working in the control box is tedius, at best. The wires are short, it's cramped, in there and there is plenty of room for mistakes.
Do dilegence first, check every ground you can find.
