Steve Mahler
- Oct 10, 2006
- 361
I have an early 70s Johnson 20hp outboard which generally runs great except for a couple problems:
1) After running for even an hour or less, one of the plugs becomes fouled. This is independent of engine speed - even high speed extended runs leave one plug fouled.
2) Because of this I am constantly changing plugs, literally one set a day if fishing on and off etc, since it has trouble cold starting with one fouled plug.
3) Even with new plugs, I have trouble cold starting the engine. 70 degrees + = two pulls max. 60-70 deg F = 4-5 pulls. Below 60 get out the paddles.
The engine runs great in all RPM ranges - idle to WOT with no smoke or hiccups. I had the carb prof. cleaned this spring, but I am wondering if my spark is not hot enough (coils?)
I just got the manual on CD on Ebay, and I just got a compression tester. This machine has been in the family since new, never left out in the rain....
All pointers appreciated - would love to know the first step in diagnosis. (i have a heated workspace to mess with it over the winter)
