I have what appears to be a very strange problem with my 1999 5L Merc alarm. I first noticed it a month ago when I went to start it up and the alarm didn't beep at all. I tested the tan/blue wire that it gets its negative power from and it showed a nice steady 13 volts when I turned the ignition on. I figured that the buzzer must have reached the end of its life (not that it should) so I went to look for a new one and found out that it was gonna cost me US$57 for a genuine part(I'm down in Oz) when I can get a little piezo buzzer from the local electronics store for $5. I went the cheaper option hooked it up, turned the key and sure enough, beep beep, it worked...
Then I heard another sound. It was very soft and high pitched, but definately coming from the buzzer. I checked the buzzer wire again, and it appears that there is always negative voltage on tan/blue buzzer wire.
My question is, should there always be some voltage on the buzzer wire? I wouldn't have thought so.
Engine starts and runs fine, plently of oil in drive lube reservoir, and it makes this soft noise when the engine is cool. Also bear in mind that it will make the standard "Beep, beep, beep" when I turn the ignition on, but a soft, high pitched warble keeps going, even when engine is started...
It has TBI so it does have an ECM. My understanding from wiring diagrams is that the buzzer output comes from the ECM. Buzzer wire (tan/blue wire) goes all the way up to the helm (via cannon plug and wiring harnesses). ECM supplies negative voltage when alarm condition is raised (ignition power up, low fluid, oil pressure, water temp.) but nominal voltage should be 0v.
I've had 2 theories on this:
1. Wire is shorting at some place or current is being induced from another power source
2. Faulty ECM giving continuous output with very low current
I tried a 1200 ohm resistor which did quiet it down a little, but it was still a little audible. I also tried a larger buzzer that drew a bit more current. It only hummed very softly (probably inaudible from more than 1 foot away, and definately will be unnoticeable by the time I replace the bathroom ceiling, close the door and start the engine) so there was obviously not enough current to run it. If I put this larger buzzer on it will solve the problem, but I fear it will only be hiding another problem.
I would love to know what other's ECM buzzer outputs are when there is no alarm condition. I suspect it is zero and that I have a wiring or an ECM fault.
Thanks in advance for any help or info anybody has.
Cheers
Chris
Cheers
Chris
