I know, it's bad luck to change you boat's name. Well, I TRIED to find a girlfriend named "Valerie T." but couldn't, so the name changes.
It peeled off OK (finger nails and razor blade) ten I cleaned the remaining adhesive off. After rubbing compound and restorer/wax by hand and orbital buffer) I still easily see where the old letters were. Maroon gelcoat looks darker under where the letters came off. It will be OK if that's as good as I can get it, but before I put the new lettering on I wanted to see if there is something else that will blend that out a bit?
Any ideas? Thanks
Any ideas? Thanks
