Hey Guys!
I'm thinking of fitting a Navman Chartplotter that also has Fuel Usage Monitoring by fitting a Fuel Flow transducer on the fuel line.
I've a 4.3L Mercruiser and need some advice on where to fit the transducer. The fittings guide says "after the fuel filter and fitted vertically". The problem is I can't see a place to fit it as most of the pipework is metal after the spin-on fuel filter.
Have you fitted one of these transducers to a Mercruiser? Where did you fit it?
Thanks
Kenny.
Thanks
Kenny.
