Re: Flushing Alpha One trim fluid?
Ok, thanks for the tips, what i did is i removed the two lines on the Outdrive, pumped out the Res. with a hand pump, filled it with, ATF and flushed the fluid out the lines on the outdrive, it worked pretty well, and there was only a little pinkish tint after all was said and done, ill have to do it agin later to get the rest out.
