I have a 1982 Johnson 150TLCNM. I am rebuilding motor. I think the carcon got to and I had some scuffing of the cylinder. Had to bore one cylinder .030 over. The piston and ring are very loose in the bored cylinder, but the box and the part number say it is .030 over fo my motor. The bore for the .030 over is actually 3.529 and the new piston diameter is 3.445. The other cylinders mic between 3.49 and 3.50 with a piston diameter ranging from 3.425 to 3.435. I was thinking the new piston would be at least 3.455. Anyway I put it all together and have low compression in the bored cylinder. I would appreciate any advice on the situation.
thanks in advance
Larry
thanks in advance
Larry
