What is the proper way to move your engine up a notch?
I noticed there is some sort of sealer around my bolts. Should the engine have sealer around it also?
put a jack with a piece of wood under the skeg of the engine, loosen bottom bolts, remove top bolts, jack engine to the desired hole and use 5200 marine sealer around the bolt holes..
