NW Redneck
- Jul 30, 2006
- 643
Off with the Merc hat, on with the OMC hat! LOL
Once again your supplicant comes to the great guru Walleyehead humbly requesting advice.
I took my 18' Cal-glass with OMC 175 out for a spin today to check my RPM's and see if my tach is working correctly now. I found out 2 things:
1: Tach is definitely hooped. Only reads 2600-2800 max, and I just checked the wires and re-made all the connections from the back of the tach to the coil.
2: My WOT rpm's are WAY too high! With the Blue Point DMM I got 4800 rpm out of that little Ford 302!
According to the speedo I'm doing 42-43 mph @ WOT with a light load. I have been cruising at 35mph as that's where the engine 'sounded happy'. At that speed I was getting 4200 rpm which is my recomended max rpm. (3800-4200) Currently running a 14 X 16 prop.
The boat is quite a$$ heavy, and has ALOT of bow rise getting on plane. Am I right in thinking I need to go up in pitch, and if so how much?
BTW, I'm planning on getting smart-tabs as soon as the funds are available to help with the bow rise issue.
Once again, Thank you!
Colin
Colin
