My new to me boat left me stranded on the lake the other day. It is a 97 Sprint F&S with a 115 Johnson.
Nothing would happen when you turned the key until I wiggled and pulled back on the throttle lever and then I had contact and the boat would start.
The other problem is because of this I can't start the boat in neutral giving it a little gas and let it warm up. You have to start it and then immediately take off or it will die.
The throttle lever is the type with the big button in the center that you push in to go to neutral.
What is causing this? If I knew the name of the faulty part could I replace it or just get a whole new throttle lever assembly?
