hookedonjc
- Dec 27, 2003
- 156
Just when you thought I was gone. I took her out yesterday and it just barely got on plane. Top end still looks OK got it up to 5800 RPM 55 MPH. I stated on my other post that when I checked timing in water sitting on the trailer at WOT I could only get 16 deg BTDC with no more adjustment. This Helped although not enuff when I put more gas in and added weight in the back and back to no planing off I checked it again yesterday I removed the rubber bushing on the stop screw to get a little more advanced and got someone to drive and I checked it while it was trying to get on plane and read 18 deg BTDC which is what book calls for But just dont seem right adjusted as far as it will go. any Ideas
One other note
If the plug wires are touching each other should you get interfearance reading on timing light or is that a sign of bad plug wires?
Thanks
Dont Ever Give Up
One other note
Thanks
Dont Ever Give Up
