There are thousands of old, complete, small outboards for sale cheap on eBay and elsewhere - in the $20 range. Elgin, Arrow, Eska, Scott Atwater, etc. Invariably the impellers are shot and replacement parts were discontinued 30 years ago. Has anyone on this forum successfully altered a new impeller for a Johnson, Evinrude, or Mercury motor to fit one of the old outboards?
It seems like if you have the old shot impeller with a decent hub you have a good start. Take a new impeller of approximately the correct diameter, shave it down to the correct thickness, and contrive a way to fit the old hub into the new impeller. Epoxy? Fit it in and then fuse the rubber to it with a propane torch? Some other ingenious technique? Surely I'm not the first tinkerer to contemplate restoring an old outboard to useful life by fabricating an impeller. Ideas?
