Re: 350 mercruiser
The camshaft in the original
marine motor should be used in the truck block.
Why,..??........
A Truck Grind is So Close to a Marine Grind,......You can Not tell Any Differences,+ It'll Work Just Fine..........
Check the heads, CC and valve sizes.
Again,....... Why,..??.....
The Heads match the Block that their Bolted Too.........
No Concerns There Either...........
Check crank for material it is made from.
Once Again,......... Why,..??.....
I'm Positive,.... It's Nodular Iron,.......
Just like the 1 in the motor he's Removing.........
Btw,........ Gene,....
You've used this thread to find Info about your Engine,...
The Title of your thread is "350 mercruiser".....
You're moving Off Topic by asking about your Outdrive,........
You'll get Much Better Replies if you start a New Thread about your Drive........
Good Luck..........
