Motor is a Johnson 81 90hp
Where do I plumb the bleeders to (ones behind the heads)
What do the check valves under the carb do and what do I hook them to
I found a small black pump (or what I think is a pump) unhooked and free in the motor pan. It has the same type check valves on it and appears to be a pump. There is spot for it mount to the motor..
I purchased this motor this way. I also noticed the carb has no choke plate on it so how does it choke.
