Re: Changed prop and lost power?
Ok, lets get some more info.
The orig prop; was it al, SS, or Bronze?
I see the al is cupped (pulled it up on the www). Was the orig cupped?
Both 3 blade?
Are either ported? Can't see that the al is.
Do you have PTT on your engine? This is very important as if one of the props has more bow lift than the other, without PTT the boat could be plowing and that could be your problem.
Compare the leading edge of both blades. Are they similar in thickness, or is the old one much thinner?
The al is said to be high rake and progressive pitch. That rake may be more than your orig and that could be the reason for the 1/4" tab spacing. Don't know if your orig was high rake and progressive pitched or not. Gonna guess no.
I think your slip numbers are correct and are caused by prop efficiency, for lack of something else to blame it on.
I think my SS Ballistic was much much more efficient at WOT than the al Hustler. However, the Hustler was more efficient at the lower rpm's and the Hustler was ported, Ballistic wasn't. Ports help you oudda de hole with da skiier.
What happened to you is similar to what happened to me in going from a Ballistic SS to a Hustler al. After lots of thought and looking around the site (and following Kenny's conversations with me and others), I am about convinced that at WOT the al is not as efficient as the SS.
That means I loose effective hp which drops my rpm's and speed. Exactly what happened to me. I lost 600 rpm's and 6 mph with the Hustler and it was 1" less pitch (and slightly larger in diameter).
However, my trim cannot go all the way up (to where I start loosing speed) because my transom has a 25 degree dead rise. So maybe I was getting less bow lift with the al and I was dragging boat. Had I been able to trim out more I maybe could have recovered my rpm's and hence speed.
Course I was running 50+ mph with a 90 hp on a 17' boat at 5600 rpm's. Maybe I shouldn't have been going that fast with that setup.......maybe I had my cake and was eating it too. 8)
Get back with the answers.
Mark
