Re: overheating
I didn't have the problem before storing it for the winter. I found the problem when I put it back in the water this year. The impeller and housing were both in good shape, so were the thermostat, circulating pump (water pump on the front of the motor) but i replaced them all anyway. I just got back from taking apart the risers and they seemed ok, I also checked the "flappers" check valves in the Y-pipe and they were fine, actually replaced them, the Y-pipe and the elbows last year. I also check the hose from the sterndrive to the transom and that wasn't kinked. I pulled off every possible hose, started the engine and had flow thru them all. I am really at a loss for words on this.
