Re: 68 evinrude 40hp won't plane out boat
I had this problem on my 1991 70 HP rude and as Paul said, the coils could be a problem. Mine too hit on all 3 during the spark test and at idle. But on the water under a load, one was shutting down on me. 3 new coils and all is well. Not saying that is the problem with yours, but it can happen...Hook up a timing light to each plug wire while on the water when this happens. This will verify if you are losing spark or not...You may also have a failing fuel pump. Have you tried squeezing the primer bulb and see if she picks up? Give that a try too...Did this happen suddenly or is this an ongoing problem?
